Re: 49 C farmall quits
Posted by Doug in OR on July 05, 2002 at 11:10:59 from (12.225.49.173):
In Reply to: 49 C farmall quits posted by Wayne on July 05, 2002 at 08:52:19:
Take one of the plug wires off and hold the tip near a grounding point while the engine is running... if you see the spark getting weaker and weaker as the engine warms up (the spark will start to turn yellow instead of the blue color), the problem will be in the magnito. I suspect the mag needs more than a rotor and cap.
Post A Followup
: Re: Re: 49 C farmall quits
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
