M runs rough, pull choke smooths out
Posted by greg m on July 06, 2002 at 10:28:41 from (209.105.135.228):
Have an M that is running rough, when I pull the choke out it smooths out nice, pulgs/points/cap/rotor all new. took carb apart cleaned looks fine.
air bleed screw turned tight, if I loosen will stall. Ideas please, check float as well.
thanks
Post A Followup
: Re: M runs rough, pull choke smooths out
