Re: 350 Rear (Steel) Hydraulic Lines
Posted by K.B. on July 06, 2002 at 14:22:04 from (209.163.14.74):
In Reply to: 350 Rear (Steel) Hydraulic Lines posted by Neal on July 06, 2002 at 11:58:50:
I had the same problem on my Farmall 240. The lines are impossible to find for a 240, so I just cut the steel lines about 10 inches from the control valve, and used compression fittings to connect the steel lines to rubber hose. Works great.
Post A Followup
: Re: Re: 350 Rear (Steel) Hydraulic Lines
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
