Farmall Tractors Discussion Board
Re: Starting my 1952 Super M; hard turning
Posted by The Red on August 16, 1999 at 12:17:44 from (206.246.187.2):
In Reply to: Starting my 1952 Super M; hard turning posted by Dan Larson on August 16, 1999 at 10:54:54:
Don ditto on what Bob says. On your choke plate, there are 2 screws, Loosen those and then adjust that choke plate so it is closing completely then retighten the screws. Sounds like you are not getting full choke.
If you are turning the distributor counterclockwise to start it, then it definitely sounds like a broken distributor spring(s) or one that got loose. Then after starting it and you advance the throttle and its running rough and you are turning the dist. clockwise to smooth it out, you most definitely have a spring(s) broken or off.
Post a Followup
: Re: Re: Starting my 1952 Super M; hard turning
