Re: F-20 runs on 2, 3 sometimes 4
Posted by Dave on July 07, 2002 at 16:57:34 from (216.42.66.62):
In Reply to: F-20 runs on 2, 3 sometimes 4 posted by SuperCmore on July 07, 2002 at 08:40:47:
Are you sure your valve clerance is right? I had similiar problem with one I bought.After about 2 hours of monkeyin' pulled off valve cover and found some loose& some too tight.Could be the cap.How bout a diff. set of plugs?
Post A Followup
: Re: Re: F-20 runs on 2, 3 sometimes 4
