Farmall Tractors Discussion Board
Re: M oil pump pressure or lack of
Posted by RED Blooded on August 16, 1999 at 13:28:30 from (206.74.34.96):
In Reply to: M oil pump pressure or lack of posted by AgMan on August 16, 1999 at 12:21:18:
Agman this may not be your problem but just a thuoght that popped into my head,how much wear is on the engine?If your bearing are in pretty bad shape you wont have good oil pressure.Also consider the fact that the gauge you just bought could be bad.Seen that happen once on a JOHN DEERE,but I wont go into that.(just a factory defect on the gauge)If everything seems to be ok you may need a pump.Hopefully yours just needs to be cleaned up.
Post a Followup
: Re: Re: M oil pump pressure or lack of
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
