Re: Another 42 A problem
Posted by Glenn(WV) on July 08, 2002 at 09:07:02 from (166.123.208.114):
In Reply to: Another 42 A problem posted by Bill (again) on July 08, 2002 at 04:00:33:
As have a certain amount of gear noise because they are equipped with straight-cut gears. It's the nature of the beast. But do check you fluid levels, like RedEd suggested. You might do well to just go ahead and change the fluids.
Post A Followup
: Re: Re: Another 42 A problem
