Re: 1939 Farmall H...Where are they all?
Posted by Bob M on July 08, 2002 at 11:30:51 from (165.170.128.65):
In Reply to: 1939 Farmall H...Where are they all? posted by Scott L. Swanson on July 08, 2002 at 11:18:35:
Scott - A friend of mine has a '39 H. It came from the factory on rubber and with electric starting/lighting. The tractor is unrestored but still works pulling hay wagons and pushing snow. The guy is a JD collector, but he keeps the old H, also a 400 on hand for when "real work" needs to be done!
Post A Followup
: Re: Re: 1939 Farmall H...Where are they all?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
