Re: 1939 Farmall H...Where are they all?
Posted by smoknbs on July 08, 2002 at 12:59:26 from (209.69.212.155):
In Reply to: 1939 Farmall H...Where are they all? posted by Scott L. Swanson on July 08, 2002 at 11:18:35:
we have a 39 H and 39M both are used every day .the H has been repainted and the motor overhauled . the M is still original. there was a guy here in michigan that had 2 39 H 's one serial # apart ,was asking 900 for both but were basket cases ,you wuold really only be buying the tags, trans cover and what was left on the seats other than having the correctly dated casting codes on the major pieces. email me and i'll try to find his # for you steve
Post A Followup
: Re: Re: 1939 Farmall H...Where are they all?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
