Re: 47 Farmal A , Can not shift into 1st or 2nd .
Posted by big fred on July 08, 2002 at 19:30:50 from (65.219.139.43):
In Reply to: 47 Farmal A , Can not shift into 1st or 2nd . posted by Todd Davis on July 08, 2002 at 19:02:49:
Sounds like there's a problem with one of the shifter forks. Take the cover off the transmission, the shifter comes with it. Then examine the shifter forks, might be something simple, but I would guess your fork is busted. If that is the case, you'll have to either get it welded back together, if the pieces are there, or get one from a salvage yard. When it comes time to put the cover back on, make sure none of the gears are engaged (transmission in neutral), then set the shifter in neutral (the notches in the shifter rails line up) and carefully set it down on the transmission case. Check all 4 gears by hand before you start the engine.
Post A Followup
: Re: Re: 47 Farmal A , Can not shift into 1st or 2nd .
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership, ... [Read Article]
Latest Ad: Variable pulley for case 1530 skid loader [More Ads]
