Re: Re: Difference between 400 and SM-TA
Posted by TP from Central PA(Sorry Ken U.) on July 09, 2002 at 16:13:44 from (64.12.103.41):
In Reply to: Re: Difference between 400 and SM-TA posted by jal-SD on July 09, 2002 at 12:52:47:
This is false, Ken U. explains this in his book. The 400 could be had with an 18(I think) or the 21 gal fuel tank, So if you had a 400 with the smaller tank it would obviously do less work than the older M's with the bigger tanks.
Sorry Ken, I only read your book every day over and over at morning during breakfast so I had to butt in ;-)
Our M-TA uses way more fuel than the neighbors 400 with the small tank!!!! However, our M-TA isn't quite stock..... Snicker.....
Post A Followup
: Re: Re: Re: Difference between 400 and SM-TA
