Re: Re: Re: Re: Re: Re: Re: Pardon my ignorance
Posted by Mike Hogan on July 09, 2002 at 17:44:14 from (12.216.50.95):
In Reply to: Re: Re: Re: Re: Re: Re: Pardon my ignorance posted by redrev on July 09, 2002 at 16:39:05:
Well, if I had a temp gauge I could tell you if it is causing any problems with heat. Currently the tractor runs fine for the hour I spend each night mowing. That's my next purchase I hate driving equipment blind, none of my gauges work, bought it that way.
I check it again with a smoke tube. Thou the tractor does have a loader on it. Which might be the reason according to one person's post.
In follow up, the blades on the fan push the air, it doesn't matter which way the pulley turns, it depends on which way the fan blades are mounted. The only reason your ceiling fan at home reverses direction is so you don't have to reverse the mounting of the blades every fall and spring when you change air direction. You just flip the switch.
Post A Followup
: Re: Re: Re: Re: Re: Re: Re: Re: Pardon my ignorance
