Re: Rusty Gas Tank
Posted by Lars on July 10, 2002 at 12:55:34 from (208.164.255.151):
In Reply to: Rusty Gas Tank posted by Wanna B on July 10, 2002 at 11:39:38:
Wanna:
One method of cleaning the fuel tank is to have a radiator shop boil it. They soak it like a radiator and then rinse with water several times.
The cost should be $75 to $100 assuming you prep the tank.
You will need to remove the fuel and wash the inside of the tank with a liquid dish detergent several times. You may want to drop a chain into the tank and shake to remove any sludge. Be careful to secure the chain so that it does fall in to the tank.
Treat the fuel with Heet (yellow bottle) or similar to remove residual water once installed.
The downside is that the process removes paint. In addition, if the corrosion is severe, it may eventually eat through the sheet metal regardless if the tank was cleaned or not. This in fact happened to me.
Another alternative is to purchase a replacement tank through a salvage yard. You may luck out find one in good condition. See if the seller will warrantee it for at least a year or see. You will need the tractor serial number and/or year to find the correct replacement.
There are other solutions. One of which is an acid etch/coating kit. The thought is to clean the tank and then apply a protective coating. Supposedly it will stop leaks. However, if the corrosion is not removed it will be trapped between the coating and sheet metal. Your local auto parts store or radiator shop may be possible source.
Good luck!
Post A Followup
: Re: Re: Rusty Gas Tank
Today's Featured Article - When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par ... [Read Article]
