Re: Re: Re: pos. ground
Posted by The Red on July 12, 2002 at 08:40:28 from (206.246.187.2):
In Reply to: Re: Re: pos. ground posted by dave on July 12, 2002 at 07:30:51:
You can take that starter plunger button apart if you like. You will see a big brass wedge on the plunger assembly and 2 brass haves that it presses into. If they are corroded, you can file them to some extent. NAPA carries a new one that is basically identical to the original one. Part number is ST6 ECH. Once you install the new cables and the starter is still not turning, you can jump directly from the battery to the starter post to see if the starter switch itself is bad. I do not recommend you trying to use a screwdriver and jumping the two posts on the switch with it being so close to the gas tank. You will get sparks!
Home
| Forums
Today's Featured Article -
Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
