Re: Re: Re: pos. ground
Posted by Doug in OR on July 12, 2002 at 11:53:29 from (12.225.49.173):
In Reply to: Re: Re: pos. ground posted by dave on July 12, 2002 at 09:12:05:
One other consideration... when you convert to 12 volts, you don't change the starter. You keep the old 6 volt starter. Because of this, you can't crank and crank and crank on the starter - you will eventually burn the starter motor out. If the tractor doesn't start after giving it a couple of cranks - no more than 15 seconds long.. spaced no closer than a couple minutes apart... find the reason why the tractor won't start... continued cranking might cause the starter motor to burn out. It is a possiblity that the previous owner burned up the starter motor this way, hence your tractor won't crank over now. Try using a jumper cable tied directly from the battery to the starter and test if the starter motor has a problem. Be careful doing this - nasty sparks can happen. Watch for the safety of your eyes.
Home
| Forums
Today's Featured Article -
Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
