Re: Re: Re: Re: Re: pos. ground
Posted by Doug in OR on July 12, 2002 at 12:03:45 from (12.225.49.173):
In Reply to: Re: Re: Re: Re: pos. ground posted by dave on July 12, 2002 at 11:53:10:
I will lay serious odds that the battery was installed incorrectly. I've never seen a positive ground alternator - others - if you are following this thread, jump in and help me here. Most conversions use a Delco 10SI alternator. They are dirt cheap and more than do the job. I suggest that you disconnect the alternator, reverse the battery... get to where you can start the tractor.. then measure the output voltage of your alternator. If you have no output voltage, just toss (well, trade in) the old alternator and buy a rebuilt Delco 10SI. I understand that they are about $39. Before installing this new alternator, make the following checks: Battery: NEGATIVE ground. Coil: The "+" or "pos" side goes to the ignition switch. They may have overlooked this detail too. Try going to http://www.geneseeproducts.com
They sell conversion kits, but if you dig into their pages, they do provide lots of good information on the conversion. Check and make sure your conversion was done correctly.
Post A Followup
: Re: Re: Re: Re: Re: Re: pos. ground
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
