Re: fuel tank sealant ? Help!!
Posted by PaulH on July 12, 2002 at 13:58:50 from (151.142.252.11):
In Reply to: fuel tank sealant ? Help!! posted by Bob on July 12, 2002 at 11:14:30:
I used the POR-15 kit on a tank for an M. I removed the outlet valve assembly, but I think you could go ahead and put the stuff in, then be sure to blow the valve out thoroughly (from the outlet) with an air hose, after distributing the sealant. I don't know, however, how you're going to get the tank clean and dry with that valve hanging on the bottom. It takes a lot of shakin' and rollin'. It would be much easier to get it out first.
Post A Followup
: Re: Re: fuel tank sealant ? Help!!
