Re: Re: farmall h fuel shut off assembly??
Posted by Bob on July 13, 2002 at 17:28:51 from (166.102.96.63):
In Reply to: Re: farmall h fuel shut off assembly?? posted by The Red on July 13, 2002 at 12:15:31:
Thanks for the advice guys! I was finally able to get the shut off assembly off and I plugged the hole with a pipe plug. Thanks Bob
Post A Followup
: Re: Re: Re: farmall h fuel shut off assembly??
