Re: Re: Farmall M cluthh replacemett-HELP!
Posted by casey on July 13, 2002 at 22:16:31 from (152.163.189.203):
In Reply to: Re: Farmall M cluthh replacemett-HELP! posted by Alton on July 13, 2002 at 19:22:10:
your nuts that you re-split youur tractor to turn around the throw out bearing. just drop your hyroluic pump(belly)
take out the center u-joint on the clucth shaft.
take out 3 alternate bolts and put them in the other clucth holes. then take out the reaming screws . once compress, take out bolts that hold thow out bearing. then slide clutch shaft back and wigle it until it drops. reverse bearing, then reverse procedures to put back together. simple 1 hr.
-casey
Post A Followup
: Re: Re: Re: Farmall M cluthh replacemett-HELP!
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
