Re: Re: I've decided to fix the ole' girl, now what?
Posted by Dan on July 14, 2002 at 09:40:43 from (12.18.158.25):
In Reply to: Re: I've decided to fix the ole' girl, now what? posted by Don LC on July 13, 2002 at 11:07:54:
I made front stands for my smta from parts off of an old IH front mount corn cultivator. the uprights were from the long tubes that go bback to hold the cultivator shanks and all. I believe the IT manual shows stands in use in it. If you have a narrow front it is king of unstable and wants to turn over so be sure the stands are plenty wide. Mine were for a SMTA. I had the front stands bolt just in front of the clutch housing unit and have screw up and down type adjustments (came from the cultivator also) I was worried about putting wheels on those due to the narrow front. I made a rear stand with a wheel on it that bolts to either side of the reaar axle housing and comes up against the bottom of the drawbar front support. My rear stand was not strong enough though to handle rear end with ta section attached, worked fine if you split it behind ta unit though and let ta center unit go with the front half. If you have a cement floor to work on, you can block the engine section up or use front stands and use a 3 ton floor jack under the back, chained to the tractor, and that works well. I had trouble finding caster type wheels that would handle sufficient weight to do the back unit. The jack setup worked the best if on a smooth floor. When I took the front pedistal out I locked the rear end up with rr ties and used a front end loader on the pedistal. I have an IT book but also the "blue ribbon service book" for my tractor. Both were handy as the IT book tends to cover a number of models generally and none specifically. When I split my smta I made dowel pins out of 5/8 bolts for the ta to rear unit and 3/4 inch bolts for front split, helps to get things lined up. If you want to e mail me I can send you a more detailed description or there should beone in the blue ribbon service book.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
