Re: 706 3pt wont lower
Posted by Mitch - MS on July 14, 2002 at 20:58:38 from (64.89.160.30):
In Reply to: 706 3pt wont lower posted by Farmall Don on July 14, 2002 at 15:08:10:
The lift on my 1066 wouldn't go down a few years back. I took the top-link bracket off and found that an arm coming down from the rockshaft housing had slipped past a piece coming up from the bottom of the tractor. I bent a piece of 3/16 rod and reached in, hooked the top arm, and pulled it back (and around) the bottom piece. When I pulled on the top arm, the rockshaft cylinder dumped and the lift arms went down. After doing this several times one day, I took one of the arms out (can't remember which now), and welded a flat washer to the side to prevent the top arm from slipping around off. This seemed to do the trick - hasn't happened since.
If this is the same trouble you're having, I may be able to remember some more details. Like I said, this happened several years ago! Just be sure you are out of the way of the lift arms when you pull the top arm back.
Hope this helps,
Mitch Sisson
Post A Followup
: Re: Re: 706 3pt wont lower
