Re: Farmall H 5th gear
Posted by Mike ISW on July 15, 2002 at 15:40:02 from (205.188.195.32):
In Reply to: Farmall H 5th gear posted by Justin - Pa on July 15, 2002 at 13:35:11:
Could be one of 2 problems. Gear shift lever where it engages shift rails may be worn. Or the fifth gear itself may be worn from 56 years of grinding into fifth from fourth. Or a combination of the 2. Good Luck
Post A Followup
: Re: Re: Farmall H 5th gear
