Farmall Tractors Discussion Board
Re: M oil pump pressure or lack of
Posted by Richard on August 16, 1999 at 19:52:10 from (156.46.71.198):
In Reply to: M oil pump pressure or lack of posted by AgMan on August 16, 1999 at 12:21:18:
I have found that most of the time on farmall pumps that the problem is that the shaft has worn the cast pump housing resulting in the pump shaft being lose,you can check it by wriggling it back and fore if it is lose the oil escapes out by the drive gear instead of being pumped into the motor. easy to fix,get another pump.
Post a Followup
: Re: Re: M oil pump pressure or lack of
