Re: Re: Re: oil seal of frontend of farmall b
Posted by CNKS on July 15, 2002 at 18:01:18 from (207.178.96.213):
In Reply to: Re: Re: oil seal of frontend of farmall b posted by steve c on July 15, 2002 at 16:33:20:
Your Case-IH dealer didn't try hard enough. Got one last week (overnight service) for my C. Apparently the housings are similar, if not identical. My C parts book says it "will work for 48776D". The part number for the C is 360457R91. If I remember correctly, the appearance of the seal has changed (as have most of them), and the dealer will cross reference to a different number. I have a good dealer. If yours doesn't want to mess with you, just go to NAPA or a bearing supplier, as the others said.
Post A Followup
: Re: Re: Re: Re: oil seal of frontend of farmall b
