Re: Re: Re: Re: Re: Re: Distributer lubrication?
Posted by Tim Shaw on July 15, 2002 at 19:52:09 from (209.74.231.218):
In Reply to: Re: Re: Re: Re: Re: Distributer lubrication? posted by Hugh MacKay on July 14, 2002 at 19:39:34:
Hugh, I'm not a mechanic either, just a Sandhills rancher. I did a little looking yesterday while I was over at the shop. An 1/8 pipe plug measures about 3/8 of an inch OD. An 1/8 NPT fitting is 27 threads per inch. A 3/8 fine thread bolt is 24 threads per inch, so even the threads look very similar between the two. Here's the rub. A bolt thread is a straight thread. A pipe thread is a tapered thread. NPT= national pipe taper. If it is indeed a bolt thread you could never tighten the plug in the hole because the plug doesn't have a head on it. I hope it doesn't sound like I'm trying to start an argument, just sharing some thoughts that I had yesterday.
Post A Followup
: Re: Re: Re: Re: Re: Re: Re: Distributer lubrication?
