Re: Antique Tractors and Synthetic Oil
Posted by Dan WV. on July 16, 2002 at 05:51:46 from (63.49.140.233):
In Reply to: Antique Tractors and Synthetic Oil posted by FC Andy on July 15, 2002 at 07:36:11:
Andy, these tractors were built when motor oil was well.......motor oil. Most of what was available was NON-DETERGENT and that is probably what your "C" was raised on. When you changed to a synthetic oil it probably has detergents in it. Look on the bottle and see. Let me try to explain what is happening to your engine. The new oil with the detergents is removing all the sludge and deposits left by years of the NON-DETERGENT oil. As you know these engines were built with fairly loose tolerences. When the deposits are removed the tolerences actually become greater with engine wear, and that is where you loose you oil pressure. But hold on it gets better. That same old oil sludge that has been in there for all these years has also been stopping internal and external leaks. Now your engine has lost pressure and is smoking and leaking all over the place. If you continue to use the new stuff it will get worse. The sludge that has been sealing off the valve seals and the piston wear is leaving and oil consumption will increase dramatically. A friend of mine did this same thing in a 52 cub and it got to the point it looked like a brush fire in the field. Shortly after that came an engine rebuild because it fouled plugs left end right. I am not saying this is the only reason for the engine demise of the cub but, I have seen this too many times to not let you know the potential consequences. My advice to you is to drain out the new high tech stuff and find you some NON-DETERGENT OIL at a tractor supply store. Your local auto parts store will probably look at you and say "did you look over by the bug shields with the rest of the oil?". Remember to replace your filter element when you do this. Good luck. Dan.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
