Re: Farmall Super A Brakes
Posted by Dave on July 16, 2002 at 07:50:58 from (138.29.36.228):
In Reply to: Farmall Super A Brakes posted by robert on July 15, 2002 at 17:25:55:
To help keep it steady while the back end is all apart, I recommend putting a long heavy pipe (6 feet or so) through the cultivator bracket just behind the steering gear. Use the same cultivator bolts that you tighten to put the cultivators on and really clamp it in place. Then block up each end of the pipe. This will keep the engine from flopping over. It's especially important when you pull the right (long axle) side, because I am not sure how well the tractor balances on the short left axle. I'd also block up under the torque tube. Also, I would pull the differential bearing housings on each side as well. This makes the seals easier to replace, and you can inspect the bearings for broken races or roller cage (which is what I had). The triangular housing and shims must be put back the exact same way they came out or the holes won't line up. I also beveled the inside edge of the seals with a file a bit to make them easier to drive into the bearing housing. Also remember that they go with the rubber lip facing in towards the differential (each side gets two seals, and they may not be identical..look at them carefully).
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
