Re: Wide front end ID
Posted by RPM on July 16, 2002 at 13:33:28 from (63.110.182.225):
In Reply to: Wide front end ID posted by Ron on July 16, 2002 at 10:54:16:
The original WFA from IH was made with steering linkage (tie rods) in front of the axle, later was behind as was all aftermarket that I have ever seen. Only way was to see if any of the parts were made of cast iron such as bolster and stay rod rear mount. This was IH only.
Post A Followup
: Re: Re: Wide front end ID
