Re: keeps running abit after shutting off M
Posted by Bob M on July 17, 2002 at 07:24:04 from (165.170.128.66):
In Reply to: keeps running abit after shutting off M posted by dave welsch on July 17, 2002 at 05:37:55:
That's pretty much normal, especially with the poorer quality gas being sold now. A few things you can do to minimize running on: Place the governor is the slowest speed position and let the motor idle for 30 - 60 seconds before pushing the switch. Make sure the carb idle mix is properly set. Adjust the carb idle stop screw so the motor idles slow (375 - 400 RPM is good). Use spark plugs 1 or 2 heat ranges cooler. Switch to higher octane (mid-grade or premium) gas.
If all else fails, put the transmission in 5th gear and step on the brakes. Then slowly release the clutch - soon as it starts to take hold hit the ignition switch. The motor will stop instantly!
Post A Followup
: Re: Re: keeps running abit after shutting off M
