Re: 450 Hyd Pressure
Posted by smoknbs on July 18, 2002 at 18:02:33 from (209.69.212.171):
In Reply to: 450 Hyd Pressure posted by BEL@IN on July 17, 2002 at 13:16:55:
Bel not sure on actual pressure rating ,however I just redid my fathers 450 .the ps was weak,would hestitate ( easy hard easy hard )I ordered all the springs check balls and o rings .put it all back together and worked better than it ever had . just remember to work the wheel from lock to lock to get the air out of system . the parts were $58 from IH dealer Steve
Post A Followup
: Re: Re: 450 Hyd Pressure
