Re: Need help with Super C please!!
Posted by BIG JOHN in KS on July 18, 2002 at 18:04:14 from (152.163.195.183):
In Reply to: Need help with Super C please!! posted by SuperCmore on July 17, 2002 at 15:05:18:
If everything else checks out OK then I would run a compression check. If your compression is way down it would explain why it would only start when you pull it. Low compression is the results of bad rings or valves being burnt or not adjusted correct. GOOD LUCK
Post A Followup
: Re: Re: Need help with Super C please!!
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
