Re: Carb adjustments on my M
Posted by The Red on July 19, 2002 at 08:38:45 from (12.84.238.174):
In Reply to: Carb adjustments on my M posted by New Owner on July 19, 2002 at 08:20:37:
The screw that is in line with the governor shaft housing is the idle speed. Turn it clockwise to increase RPM. The screw close to that one is the idle mixture screw. The bottom one is the high speed mixture screw. Open that one up about 1/2 more turn counterclockwise.
Post A Followup
: Re: Re: Carb adjustments on my M
