Re: 1943????????? What Went On
Posted by G-MAN on July 19, 2002 at 15:55:03 from (206.106.139.74):
In Reply to: 1943????????? What Went On posted by BIG JOHN in KS on July 19, 2002 at 13:24:06:
Sounds real similar to what JD did (in regards to the difference in "H" and "M" production). I don't believe they built any "G"s during 1943, because it was deemed smarter to build a larger quantity of smaller tractors than a smaller quantity of larger tractors. Nearly two "B"s could be built out of the same raw materials required to build one "G", so that's what they did. Lot's of farmers that wanted the bigger tractors made do with the smaller ones until after the war.
Post A Followup
: Re: Re: 1943????????? What Went On
