Dating on a tractor
Posted by to Scott on July 19, 2002 at 18:29:19 from (206.243.129.240):
Scott,
don't feel too bad about the bookstore clerk not liking the Farmall book. And if she doesn't want to go for a ride on your restored H then tell her you will leave it for her in her front yard as a permanent lawn ornament until she goe to the ice cream store with you.
And G-Man may have a point: pick up a book on Male Sensitivity and how treat a woman right. Ask her if she could provide a good recommendation to a similar subject and book. Once the ice is cracked, and if she shows no interest in you and your H, then recommend a book for her to read. I'm sure, at that point, you will have a decent title in your mind. BUT Never give up. Be persistent, and drive back and forth by the front of the bookstore on your H and keep waving. Eventually you will wear her down...hopefully before you wear down the treads on your tires.
good luck
Post A Followup
: Re: Dating on a tractor
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
