Re: 584 braking problem
Posted by RPM on July 20, 2002 at 06:42:40 from (63.110.182.225):
In Reply to: 584 braking problem posted by At wits end on July 18, 2002 at 07:21:33:
Brakes on 74/84/85 series were not my favorite to fix, they have a brake equalizer valve, and cyls for each brake side, then the orings on the actual piston that is mounted on inner end of axle. The brake cyls can be resealed, the equalizer replaced, then remove the axle & housing to replace the orings on the actuator piston.
Post A Followup
: Re: Re: 584 braking problem
