Re: Re: What exactly is distillate?
Posted by Gene..found the file on July 21, 2002 at 11:37:15 from (65.56.219.172):
In Reply to: Re: What exactly is distillate? posted by Gene on July 20, 2002 at 20:14:00:
: Distillate is simply the left over parts of crude oil after the more popular fractions have been distilled out! Hence the name.....
: : Basically, you'd take the crude oil and heat it in a still. The different hyrdocarbons in the crude mix will distill out in order of their complexity.
: : Methane (one), Butane (two), Propane (three), etc. All come out in order as gas and are sent to storage facilities at the well sites (usually). The crude oil is a mix of all of the liquid (at normal temperatures) HC chains. If you heat it up, the liquids turn into gas, with the lighter ones boiling off first, followed in succession by the heavier ones. The crude oil in the still will settle out at temperature points, which tells you what fraction is boiling off currently.
: : Now, since you want reasonably pure Gasolene, Kerosene, diesel, etc. you have a point where the liquid in the still is ramping to the next temperature point; you need to dump the output during the ramping into a different container. Once the temp. stabilizes at the next point, you switch the output to the pipes leading to the specific storage tanks (gas, kero, etc.)
: : So, when you're done with this process you have a number of tanks containing specific grades of fuels, and an extra tank containing a mixture of all of the fuels. This extra mixed fuel was referred to as distillate!
: : Now, you wonder where you can get it today? You can't! It hasn't existed since 1943! you see, the oil refining process was forever changed as a result of the Second World War!
: : A process for making a barrel of crude oil into a barrel of gasolene was needed to fuel the war effort. The distillation process was replaced by the cracking process.
: : Cracking involves a catalytic process whereby all of the HC chains in the crude are split in to single HC molecules. Then, these molecules are recombined into the required HC chains necessary to produce a specific fuel (Gasolene, Kerosene, Diesel, etc).
Post A Followup
: Re: Re: Re: What exactly is distillate?
