Farmall Tractors Discussion Board
Re: M oil pump pressure or lack of
Posted by JK MN on August 17, 1999 at 07:48:33 from (207.242.199.131):
In Reply to: M oil pump pressure or lack of posted by AgMan on August 16, 1999 at 12:21:18:
AgMan,
This is the way we would "test" the IHC pumps that have the drive shaft. After cleaning, leave the pump immersed in the solvent and turn the shaft by hand, and plug the outlet with your thumb or finger and feel the pressure build, it should be almost instantious, and NO liquid should be squirting from around the shaft. If the pump will pump and build pressure with the solvent by hand, it will pump engine oil when turned by the engine.
Post a Followup
: Re: Re: M oil pump pressure or lack of
