Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: breaking in a farmall h?
Posted by Bob on July 21, 2002 at 14:46:14 from (166.102.96.27):
In Reply to: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: breaking in a farmall h? posted by The Red on July 21, 2002 at 11:06:45:
Help!! Red I tightened the packing nut in some but still couldn't get the needle to seat
so I started it up and adjusted the idle screw first it seemed to run real good with the screw all the way in. I thought this was strange but it sounded good and wasn't smoking so next I went to adjust the main screw, when I went to bring the throttle all the way up, it accelerated at then died! So i brung the throttle back down and tried starting it again, it started but would only run for a 2 or 3 seconds then die again. So I thought maybe the idle screw all the way in was the problem, so I turned it 1 and 1/2 turns out and got the tractor started but it still died in 2 to 3 seconds. I tried turning the packing nut back out to where it was but the tractor still only runs for a few seconds. I noticed it is harder to get started now. Do you think maybe I crushed the packing nut and pieces of it got sucked into the carb? Any help would be appreciated!!!! Thanks Bob
Post A Followup
: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: breaking in a farmall h?
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
