Farmall Tractors Discussion Board
Re: Farmall Cub Maintenance
Posted by Phil Auten on August 17, 1999 at 07:50:58 from (206.175.72.226):
In Reply to: Farmall Cub Maintenance posted by John on August 16, 1999 at 19:03:26:
Scott,
The S/N plate on CUBs is on the front casting next to where the steering shaft enters the casting. To check the oil on most IHC tractors of that vintage, there are two petcocks on the side of the oil pan. Fill till oil just starts to ooze out the top petcock. If oil doesen't come out the top one, open the bottom one. If oil doesen't come out the bottom one, close it and open the top one and fill till it just starts to come out. (If oil doesen't come out the bottom one, I would do an oil change).
The engine S/N is on the carb side of the engine to the right of the carb. This might give you an idea of when the tractor was built unless the engine has been replaced. A lot of CUBs no longer have their S/N plate since the front casting is part of the radiator. An unexpected freeze without antifreeze in the cooling system would crack these castings and they would be replaced, taking the S/N tag to the dump with them.
Good luck,
Phil
Post a Followup
: Re: Re: Farmall Cub Maintenance
