Re: water temperature gauges
Posted by Bob M on July 22, 2002 at 18:15:24 from (24.169.120.138):
In Reply to: water temperature gauges posted by Charlie on July 22, 2002 at 17:45:39:
I've had mixed results with those gages - some work OK for several years, others don't last a season, or don't work right out of the box. However a low temperature indication also could be from bad thermostat causing the motor to run cold.
A quick test: Remove the thermometer bulb from the head. Boil a pot of water and quickly immerse the bulb in the hot water. If the gage is reading correctly the needle will go up almost to the right end of the "RUN" band - to the little arrow mark above the band.
Post A Followup
: Re: Re: water temperature gauges
