Re: Early A manifold????
Posted by Red Dave on July 23, 2002 at 07:08:49 from (24.104.94.34):
In Reply to: Early A manifold???? posted by Courtland on July 22, 2002 at 19:10:29:
I don't have the parts cd here right now to verify it, but as far as I know, the gasoline manifolds are all the same. Distilate manifolds are a little different I think, but they should still be interchangable.
I put a new manifold on a '40 B last year (same engine as your A) that I got from a Case/IH dealer and it bolted right up, no problems.
Where did you get your manifold from?
Post A Followup
: Re: Re: Early A manifold????
