Re: Re: Re: 1953 sm (grounding)
Posted by Bob M on July 23, 2002 at 18:27:47 from (24.169.120.138):
In Reply to: Re: Re: 1953 sm (grounding) posted by bud bareenie on July 23, 2002 at 17:50:37:
Hey Bud - I did the same thing to my stock (6 volt) Super H as well. Found the starter spins it faster than when the battery was grounded thru the battery box. ...Bob M
Post A Followup
: Re: Re: Re: Re: 1953 sm (grounding)
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
