Re: 12 volt system conversion
Posted by Doug in OR on July 23, 2002 at 18:28:26 from (12.225.49.173):
In Reply to: 12 volt system conversion posted by JD Humm on July 23, 2002 at 16:09:18:
Is your charging system working properly? When the tractor is running and at about half throttle, put a voltmeter across the battery. Use a fairly decent voltmeter; one with a real meter movement. Are you reading a solid 13.8+ volts?
Post A Followup
: Re: Re: 12 volt system conversion
