Re: Re: is it possible to get a 450 under 6000 lbs.
Posted by matt on July 23, 2002 at 22:27:03 from (66.19.108.190):
In Reply to: Re: is it possible to get a 450 under 6000 lbs. posted by Dan on July 23, 2002 at 22:06:09:
yea, I'm going to put a standard drawbar on there, but I think at most it could save me 100 lbs. I know my uncle has a MD, which is basically the same tractor minus the TA, that weighs under 6000. My dad took the fluid out of the tires by getting the valve stem to the bottom and then letting it drain. I can siphon the last little bit out with a small tube if need be.
Post A Followup
: Re: Re: Re: is it possible to get a 450 under 6000 lbs.
