Re: 1953 sm (grounding)
Posted by John (SC) on July 24, 2002 at 02:46:05 from (206.74.34.103):
In Reply to: 1953 sm (grounding) posted by bud bareenie on July 23, 2002 at 13:28:15:
Hey Bud.That sounds more like a fuel problem than a grounding problem.if it were a grounding problem it would be there all the time not just when you work it hard.I wouls suspect the float is just a tad off.
Post A Followup
: Re: Re: 1953 sm (grounding)
