Farmall Tractors Discussion Board
Re: Super A rear wheel seals.
Posted by Daniel on August 17, 1999 at 10:32:20 from (206.74.50.21):
In Reply to: Super A rear wheel seals. posted by Rich Benson on August 16, 1999 at 22:24:51:
Inside the final drive housings there is a domed cover on each side. (unless you have a gear to drive a fert. dist. or planter)Under the cover is a bolt that holds the axel. Drop the pans on the final drive and put a piece of plywood under the gear, be ready to catch it when it falls. Note which is the inside of the gear, it will go back both ways but only work the right way. The felt seal ring in the outer axle cover is a pain in the neck to put back in. Good luck. Daniel. DAH2888@aol.com
Post a Followup
: Re: Re: Super A rear wheel seals.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
