Re: 3 point hitches
Posted by Keith on July 25, 2002 at 14:37:46 from (66.129.8.2):
In Reply to: 3 point hitches posted by SC on July 25, 2002 at 11:59:58:
I have a 3point conversion made by "Cornhusker" that I have not put on my tractor yet but am planning to soon. The top link hook up is built onto the frame of the unit and it has two cylinders, (one for each arm) to lift. It bolts to the drawbar support but has a horse shoe type bracket that comes up where the unit meets the tractor and that is where the top link bracket is. It is very heavy and built tough. I bought it from a guy that took it off an H and he said it worked great. I know it won't float or have draft control but it will still make my little tractor more useful. I just have lots of other things to do to the tractor before I can put it on. Good luck.
Post A Followup
: Re: Re: 3 point hitches
