Re: Re: Hard starting BN
Posted by ScottyNY on July 26, 2002 at 11:46:24 from (151.202.185.143):
In Reply to: Re: Hard starting BN posted by Sabula Rodger on July 26, 2002 at 09:34:40:
If your valves are ok and compression is ok you'll have vacuum. Compression will vary depending on the head, but 90-100# would be pretty good. Vacuum is measured differently because it doesn't peak in the same way as compression, but again, if your valve are ok . . . If you pull the plugs and have someone turn the engine by hand you can feel the vacuum at the plug hole. One of the easy ways to test for/find a vacuum leak is to get the engine running and spray a volatile like starting fluid or carb cleaner around the places that it might be leaking air (especially the manifold, including where the carb bolts up). If the engine speeds up, you've found a leak. That brings to mind, you said you replaced or rebuilt the carb. Do you have a tight fit at the gasket from the carb to the manifold? Sometimes if you tighten too much, the threads on the carb will strip and you'll not get a good seal there.
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
