Re: Attaching a sickle bar mower to a Super A?
Posted by Hugh MacKay on July 26, 2002 at 16:53:30 from (209.226.247.139):
In Reply to: Attaching a sickle bar mower to a Super A? posted by SAm in NS on July 26, 2002 at 13:44:05:
Super A had mowers that mounted on rear of tractor as well as mid mount mowers. Rear mount should be model no. 16 and centre mount should be model no. 22. There was a cub version and A, SA, 100, etc version.
If numbers are no longer visable on mower, look for a mounting device that hooks to both sides of clutch housing and goes down and back at about 45 degrees. this holds a shaft that goes back and is belt driven by pto, V belt. Also look for a 8 inch diameter V pully that fits your pto. If you have all these items you have the centre mount mower. This mower will likely be components.
Rear mount mower mounts where drawbar mounts and will be shaft driven to mower. Let me know which you have and will give you more info.
Post A Followup
: Re: Re: Attaching a sickle bar mower to a Super A?
