Re: A couple of really stupid questions
Posted by Doug in OR on July 26, 2002 at 23:25:50 from (12.225.49.173):
In Reply to: A couple of really stupid questions posted by Scott (TN) on July 26, 2002 at 19:46:46:
The alternator isn't putting anything out if you are reading 12.6 volts. That is normal 12 volt battery voltage. You need 13.8 volts to charge a battery. Also, a GM alternator needs to turn at 1200 RPM, minimum, to start charging.... considering that most older IH tractors turn around 450 RPM at idle, you want a 3:1 pulley ratio, if you can find a small enough pulley for the alternator. If you can't get 3:1, shoot for 2.5:1 One last item: on the Delco alternator, be sure that pin 1 is tied to your ignition switch - either through a diode or through a light. You need this voltage at startup to tell the alternator to start charging. Single wire alternators are okay, but 3-wire alternators charge better at the lower sppeds you find on thactors.
Home
| Forums
Today's Featured Article -
Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
